[GRASS-user] Re: [winGRASS] native winGRASS pre-alpha testers needed
Moritz Lennert
mlennert at club.worldonline.be
Wed Sep 5 04:18:38 EDT 2007
On 04/09/07 14:21, Ted Nebitko wrote:
> Is there an index of those modules that are working and those that
> require further testing?
There is no such systematic index. What we know not to work at this stage:
- some modules dealing with attributes of vector data (confirmed for
v.out.ogr, but others are affected): these work intermittently, but
often cause deadlocks. We are currently busy trying to hunt down this bug.
- all d.* commands from the command line: there are no x-monitors in
windows so none of these commands will work. All display has to happen
within the GIS Manager gui.
- d.vect.thematic: this is a script which cannot easily be ported to
windows as it uses d.mon commands.
- There might be other scripts that don't work.
The rest potentially works, but still needs extensive testing since
whether a module works or not might depend on the parameters used.
Moritz
