[GRASS-user] r.resamp.rst Producing Bad Values
Glynn Clements
glynn at gclements.plus.com
Fri Sep 7 16:09:57 EDT 2007
Hamish wrote:
> > The problem still occurs in all cases. I would simply work around it, but
> > r.mapcalc will not replace "nan" values. I am out of ideas. Any suggestions?
> will r.null replace "nan" values? If not, we should probably add a flag to
> r.null to allow that.
We should look into changing G_is_[fd]_null_value() to test for any
NaN value, rather than for the specific bit patterns which GRASS uses.
If we have isnan() (C99), we can use that. For IEEE-754, NaN has an
all-ones exponent and a non-zero mantissa. Testing for x!=x may also
work.
