[GRASS-user] errors in last cvs
Glynn Clements
glynn at gclements.plus.com
Mon Sep 10 22:04:03 EDT 2007
"Carlos \"Guâno\" Grohmann" wrote:
> Just updated from cvs. Got an error with r.neighbors (below) and now
> gis.m complains that <map> is not valid, so I can't have zoom to map,
> etc.
> cheers
> Carlos
> guano at eclipse:~/tmp_install/gis/grass6/raster/r.neighbors$ make
> gcc -I/home/guano/tmp_install/gis/grass6/dist.i686-pc-linux-gnu/include
> -march=prescott -O2 -pipe -fomit-frame-pointer -Wall
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
> -I/home/guano/tmp_install/gis/grass6/dist.i686-pc-linux-gnu/include \
> -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> main.c: In function 'main':
> main.c:132: error: expected expression before '<<' token
> main.c:135: error: expected expression before '==' token
> main.c:138: error: expected expression before '>>' token
You got a conflict during update; the output from "cvs update" will
have:
cvs update: conflicts found in driver.c
C raster/r.neighbors/main.c
This occurs if the file has been locally modified in a way which
conflicts with changes to the CVS version, such that the two sets of
changes cannot be merged automatically.
If you want to keep your local changes, you will need to edit the
portion of the file between the <<<<<<< and >>>>>>>, resolving the
different versions. Otherwise, just delete main.c and update again.
