[GRASS-user] solving libgdal.so.1 problem without root permissions
dziadgba dziadgba
dziadgba at googlemail.com
Tue Sep 11 16:33:17 EDT 2007
hy,
thanks for help: resolved the problem by installing GDAL and setting:
setenv LD_LIBRARY_PATH "$LD_LIBRARY_PATH":[path to gdal]/gdal/lib/
bye
dziadgba
2007/9/11, Maris Nartiss <maris.gis at gmail.com>:
> Hi,
> this error means that Your GRASS installation can not access GDAL
> library. First You have to check is GDAL/OGR library installed on that
> system. Most likely it is not. There are only two solutions then:
> 1) Ask system administrator to install GDAL/OGR and GRASS;
> 2) Install GDAL/OGR and GRASS from source in Your home directory and
> set up manually all paths (LD_LIBRARY_PATH, PATH).
> Maris.
> 2007/9/11, dziadgba dziadgba <dziadgba at googlemail.com>:
> > hy everybody,
> > I would like to do some longer calculation on a computer for which I
> have an
> > acccount but I do not have the root password.
> > after installing grass6.2 I got the know error
> > g.remove: error while loading shared libraries. libgdal.so.1: cannot
> open
> > shared object file.
> > I saw the answers to previous posts with:
> > /etc/ld.so.conf, "ldconfig" as root.
> > but as I can not access as root how could I overcome the problem?
> > thx
> > dziadgba
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070911/217e5785/attachment.html
