[GRASS-user] 6.3 CVS error opening workspace
Adam Dershowitz
adershowitz at exponent.com
Wed Sep 12 17:38:11 EDT 2007
I just upgraded from my 6.3 CVS build, and I can no longer open my
workspace files, that I created a few weeks ago with the then current
CVS build.
if I try to open my prior .grc workspace files I get an error. The
GIS manager lists single layer and then I get a popup error: Error:
syntax error in expression "[c...
If I then click to get details I see the following errors:
syntax error in expression "[catch {GmTree::node_type $current_node}]
error ": extra tokens at end of expression
("if" test expression)
while compiling
"if {[catch {GmTree::node_type $current_node}] error } {
Gm::errmsg $error [G_msg [format "Could not open %s - bad file
format" $fpath]]
brea..."
("default" arm line 2)
invoked from within
"switch $key {
Group {
if {[regexp -- {^File (.+)} $val r leftover] && ($leftover !=
$filename($mon))} {
set val "<-- $leftover"
(procedure "GmTree::load" line 39)
invoked from within
"GmTree::load $filename($mon)"
(procedure "Gm::OpenFileBox" line 12)
invoked from within
"Gm::OpenFileBox"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb1.bbox3.b1"
(command bound to event)
I am using Kyngesburye's Mac binaries. I created the .grc files with
his 8/29/07 binary, and now I can't open them with the 9/10 binary.
Any ideas what broke or what I can do to fix it? Was there a change
in the .grc format that will not allow parsing of a slightly old file?
Thanks,
--Adam
