[GRASS-user] new error window
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Sep 17 15:26:37 EDT 2007
Carlos "Guâno" Grohmann wrote:
> Those errors are related to some changes I did to gis.m, which are the
> "info" buttons for raster and vector in gis.m.
> For some reason, they are not working in the cvs. If I replace
> raster.tcl and vector.tcl for the version that is attached, it works.
> The attached version also adds a button for "set region to map"
> (raster and vector). I use it a lot, I don't know if it would be of
> general interest.
> If you want to try, just replace the .tcl files in $GISBASE/etc/gm
> with the ones in the attachment, and add the icons to
> $GISBASE/gui/icons
> Carlos
> On 9/17/07, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
>> Hi
>> After yesterday updating of grass CVS new issue in tcl/tk gui appears:
>> when I refresh display window, completly new window (looks like  r.info
>> message) appears with following message:
>> <map> is not correct parameter (or simillar, massage is in polish)
>> ERROR requiered parameter of <INPUT> is not set .....
>> next is r.info help text
>> how to switch off this massage (where in code)? After several clicks it
>> became  frustrating....
>> Jarek
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
thanks Carlos I tried It works.
Set region to map seems to be good idea. Anyway, it not disturb :)
Jarek
