[GRASS-user] whats going on with v.to.rast?
Markus Neteler
neteler at itc.it
Wed Sep 19 03:46:19 EDT 2007
Hamish wrote on 09/19/2007 04:53 AM:
> Maciej Sieczka wrote:
>> Markus Neteler wrote:
>>> On Mon, Sep 17, 2007 at 07:32:08PM +0200, Maciej Sieczka wrote:
>>>> The message in 6.2 is missleading though. This is fixed in 6.3. The
>>>> message would be "ERROR: Cannot open existing vector <name> on level
>>>> [2]" in 6.3.
>>> Which are precisely the messages? Then we could fix it in 6.2.
>> In 6.2 it's:
>> ERROR: Cannot open old vector map at mapset on level 2
>> In 6.3:
>> ERROR: Cannot open existing vector <map at mapset> on level [2]
> It doesn't seem too misleading to me. Not enough to risk backporting
> changes.
Hamish: where is a risk to change a message?
> Also, IMO the [] should be removed from the "on level ..." part
> as the "2" is part of the sentence, it's not parenthetical.
> The crux of the problem is that the various vector levels are not well
> documented or known about. It's not obvious at all what "level 2" is or
> means. We should work on the problem from that angle, starting with
> something in the vector section of the wiki. (too technical for the
> vectorintro.html page I think)
In the first place it should go into the programmer's manual (doxygen):
http://mpa.itc.it/markus/grass63progman/level_8c.html#faba88262f7841017ff371cd429591c6
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
