[GRASS-user] problem in v.out.ogr postgis
temiz temiz at deprem.gov.tr
Thu Sep 20 11:32:46 EDT 2007
hello
I want to transfer grass vector (line) to postgis by this command:
v.out.ogr input=hey_el86 type=line dsn="PG:host=localhost dbname=bzk2
user=postgres" olayer=shey_el86 format=PostgreSQL
at postgis side:
SELECT cat, isclosed(wkb_geometry) from shey_el86;
cat | isclosed
   1 | t
   1 | t
all closed ring. It shouldn't happen.
They shoud be all line with different starting and end coord points.
select cat,astext(pointn(wkb_geometry,1)) as first_pt
,astext(pointn(wkb_geometry,npoints(wkb_geometry))) as last_pt from
shey_el86 ;
gives :
 cat |                 first_pt                        |
last_pt
   1 | POINT(468597.760453644 4630916.47967991) | POINT(468597.760453644
4630916.47967991)
you see first point and last point are the same.
I checked the view from the grass monitor. They should not be closed ring.
how can I solve the problem ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
