[GRASS-user] NVIZ - tiled legend in maximum resolution ppm
Thu Sep 20 22:02:14 EDT 2007
> > Jarek Jasiewicz wrote:
> >> In Nviz when I need to save visualisation as maximum rosolution ppm,
> >> and I have legend added, the legend (but not the north arrow!) is
> >> tiled over the image regulary  12 times.
> >> There are no such problems in saving as normal ppm or tif.
Hamish:
> > is the rest of the image ok, is it just the legend which is repeated?
> > see bug #3041
> >   https://intevation.de/rt/webrt?serial_num=3041
> > does it work ok for you if you use GRASS 6.2.2?
Jarek:
> I tried by I cannot place a scale in grass 6.2.2 (in fact I almost have
> never used that version of grass, so cannot say why) so  I cannot
> answer this
> > does it work ok if you don't use a legend?
> All render ok exept legend, anyway legend is added or not
I would suggest filing a new bug report in the bug tracker for this.
For now as a work-around you might make an image with and without the
legend, and then cup&paste the legend into the clean version in a paint
program.
Hamish
