[GRASS-user] 3D Imaging from Medical JPEGs
Wolfgang
wollez at gmx.net
Sat Sep 22 07:16:14 EDT 2007
Carl Brown wrote:
> Is it possible to construct 3D images using GRASS from jpeg sources?
> CT scans and MRI scans are examples. The images are lossless grayscale jpeg
> format. (There is a standard called DICOM which would probably be the target
> of any serious work) Each image represents a "slice" with a known position,
> resolution and orientation. A number of slices are spaced at a known
> incremental spacing in the third dimension. It looks like a perfectly good 3D
> data source to me!
> In simple terms, all that needs to be done to get started is to stack the
> slices into a 3D raster map, so as to be able to render them using NVIZ, for
> example, or for any other uses that anyone might devise for any other
> existing GRASS functionality.
> Is anyone playing with this type of application?
you won't find many functionality for the reconstruction of 3D elements
from your images in grass. perhaps you should have a look at
VTK http://www.vtk.org/
ITK http://www.itk.org/
Paraview http://www.paraview.org
regards
Wolfgang
