[GRASS-user] Problem using r.in.wms with saxonys mapserver
Agustin Diez Castillo
Agustin.Diez at uv.es
Sat Sep 22 14:39:06 EDT 2007
Try without the folder flag , it works for me ... some times. I've
been fighting with r.in.wms for several months and usually I got
stuck either where your are or at WARNING: xml2 NOT avaliable, I was
told that xml2 is not needed -I'm on mac- what is true in some cases -
see below-.
Those errors only happen in some servers.
r.in.wms -l output=icvo5_2004 mapserver=http://ovc.catastro.meh.es/
Cartografia/WMS/ServidorWMS.aspx? layers=hist_1_5000_2004 srs=EPSG:
23030 format=png wmsquery=version=1.1.1 maxcols=2048 maxrows=2048
'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -S'
method=nearest v=1 --o
Using WGET for downloading data.
List of layers for server
http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?:
20:22:15 URL:http://ovc.catastro.meh.es/Cartografia/WMS/
ServidorWMS.aspx? [316/316] -> "/Volumes/LaCieDisk/Users/Shared/
agus_compartido/grassdata/Projecte/adiez2/.tmp/regadiuet.prearq.uv.es/
1486.0capabilities.xml" [1]
ERROR: Parsing XML file
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidFormat">
<![CDATA[
Este servicio sirve para ser utilizado por programas de visualizaci?n
de cartograf?a. No es una p?gina web.]]>
</ServiceException>
</ServiceExceptionReport>
but not in others
r.in.wms output=icvo5_2000b mapserver=icvmapas.icv.gva.es/wms?
layers=hist_1_5000_2000 srs=EPSG:23030 format=png
wmsquery=version=1.1.1 maxcols=2048 maxrows=2048 folder=/Users/adiez/
Documents 'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -
S' method=nearest v=1 --o
Calculating tiles
Requesting 1 tiles.
Downloading tiles
Downloading data
Requesting Data from icvmapas.icv.gva.es/wms?:
request=GetMap&layers=hist_1_5000_2000&styles=&srs=EPSG:
23030&bbox=699869.94641300000000000000,4274950.58941000000000000000,7499
46.91542798501498496500,4325027.56334589610389605391&width=2004&height=2
004&format=image/png&transparent=TRUE&version=1.1.1
20:33:34 URL:http://icvmapas.icv.gva.es/wms? [24012] -> "/Users/adiez/
Documents/icvo5_2000b__0.png" [1]
All tiles downloaded successfully
Creating output file that is 2004P x 2004L.
Processing input file /Users/adiez/Documents/icvo5_2000b__0.png.
Using band 4 of source image as alpha.
Using band 4 of destination image as alpha.
:0...10...20...30...40...50...60...70...80...90...100 - done.
Projection of input dataset and current location appear to match.
Proceeding with import...
100%
100%
100%
100%
On Sep 22, 2007, at 12:20 PM, gweigi71 wrote:
> Hello,
> I try to get some maps from saxonys new wms- service:
> http://www.landesvermessung.sachsen.de/ias/basiskarte/service/register
> (german only)
> I use this with grass 6.2.2:
> r.in.wms -c output=tk10
> mapserver=http://www.landesvermessung.sachsen.de/ias/basiskarte/
> service/SRVTKFREE/WMSFREE_TK/wmsservice?
> layers=tk10w,tk10g,tk10i,tk10v srs=EPSG:31468 format=png
> wmsquery=SERVICE=WMS&version=1.1.1 maxcols=1024 maxrows=1024
> folder=/home/wg/toposachs {wgetoptions=-c -t 5 --user-agent=MSIE5.5}
> method=nearest v=1
> ... and I get this:
> ERROR 4: `/home/wg/Documents/grass6/wms_download/tk10__0.png' not
> recognised as a supported file format.
> ERROR: r.in.gdalwarp: gdalwarp failure.
> Also there are only empty png's in the download folder (and some other
> files). I think it has something to do with scalehint- restrictions.
> Maybe my region- settings are wrong:
> projection: 99 (Transverse Mercator)
> zone: 0
> datum: potsdam
> ellipsoid: a=6377397.155 es=0.006674372231802145
> north: 5666684.25180855
> south: 5665398.55006475
> west: 4683933.19530855
> east: 4685477.48200981
> nsres: 0.99976807
> ewres: 1.00018569
> rows: 1286
> cols: 1544
> cells: 1985584
> Can somebody give me a hint?
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070922/977e9af0/attachment.html
