[GRASS-user] r.out.gdal bug? problems with createopt
Robert Nuske
rnuske at gwdg.de
Sun Sep 23 12:13:31 EDT 2007
Moin Markus,
thanks for looking into my problem.
> it seems to be the same bug as it was found and fixed in v.out.ogr
> some days ago by Martin.
> I debugged a bit and found that the second part
> "PROFILE=BASELINE" isn't passed. It gets lost in
> main.c, line 554.
I am not sure this is the only problem.
r.out.gdal [...] createopt="PROFILE=BASELINE"
doesn't work either
cheers,
robert
> v.out.ogr's main.c (line 249 etc) has a working solution
> but my try to port it to r.out.gdal failed (no idea why, should be
> rather easy - but it segfaults for me).
> So - we are close to a solution :)
> Markus
> Robert Nuske wrote:
> > Hi List,
> > I am trying to export a floating point raster into a tiff, BUT without
> > writing
> > a GeoHeader (no GeoTiff!).
> > ( I want to do this rather unusual thing, because the PCI Geomatics
> > Software
> > has Problems with the Gauss Kruger Projection. It misinterprets a good
> > looking GeoTiff and writes only garbage in the GeoHeader of its output.
> > But
> > if one feeds it just coordinates they line up perfectly.)
> > r.out.gdal [...] createopt="TFW=YES,PROFILE=BASELINE"
> > writes always a GeoHeader!
> > According to the GDAL documentation (http://www.gdal.org/frmt_gtiff.html)
> > it
> > should not write any Geo-Stuff, if given the option PROFILE=BASELINE.
> > I then tested the scripted version
> > r.out.gdal.sh [...] createopt="TFW=YES,PROFILE=BASELINE"
> > and luckily it behaves and writes a tif without GeoHeader.
> > cheers,
> > robert
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
