[GRASS-user] d.text fail to load the font (osx)
    massimo di stefano
    massimodisasha at yahoo.it
    Tue Sep 25 09:43:21 EDT 2007
i'm tring to use
d.text  on grass-6.3.cvs  builded from source on a mac osx
i'm tring to use it as described inthe help menu,  but it fail to
load the font:
GRASS 6.3.cvs (wgs):~ > d.text << EOF
 > .C yellow
 > .S 4
 > .B 1
 > This is a test of d.text
 > EOF
WARNING: unable to open font map
          '/Applications/GRASS-6.3.app/Contents/MacOS/fonts/.hmp': No
such
          file or directory
while using a line like :
d.mon x0
d.text 'text=text to display' size=5 color=gray align=ll rotation=0
linespacing=1.25 path=/Applications/GRASS-6.3.app/Contents/MacOS/
fonts/italiccs.hmp
nothing is displayed.
i tried again using interactive place text flag :
d.text -m 'text=text to display' size=5 color=gray align=ll
rotation=0 linespacing=1.25 font=italics path=/Applications/
GRASS-6.3.app/Contents/MacOS/fonts/italiccs.hmp
but  while the menu :
Click!
Left:    Place text here
Right:   Quit
is corrected displayed,
in the window "Output - Gis.m"
i've the same message :
unable to open font map '/Applications/GRASS-6.3.app/Contents/MacOS/
fonts/.hmp': No such file or directory
seems that it do not use a "name"  for the font, but only the
extension is passed to the command.
i'm missing something,  like i need to set a font first ?
or it is a knowed problem?
instead of d.text, now  i'm using d.text.freetype without problems
(works really fine)
using as font the path to the x11 font (as described in the help).
