[GRASS-user] problems with db.execute
Moritz Lennert
mlennert at club.worldonline.be
Wed Apr 9 10:14:05 EDT 2008
On 09/04/08 16:00, Isabel Alfaro Cardozo wrote:
> I cant get db.execute to work it seems to be a problem with the sql
> statement file, does someone has an example? thank you a lot
See the man page, it has examples.
If that does not help, it might be easier if you sent us your sql file
and the db.execute command line you use and the error message you get.
Moritz
