[GRASS-user] v.in.ogr from PostGIS
Leonardo Lami
lami at faunalia.it
Wed Apr 9 11:54:19 EDT 2008
Hi all,
I'm trying to import a PostGIS table in GRASS by v.in.ogr.
in this table there is a field 'id' that is a primary key, the
importation works well and I have a correct GRASS vector but if I look
the table I see that the field 'id' lacks.
If i make the same operation with a copy of the original PostGIS table,
where the field 'id' is not a primary key, I have a GRASS vector with
the field 'id' is present on its table.
Do you know if this is a problem of v.in.ogr or of the ogr library?
Thank you
Leonardo
