[GRASS-dev] Re: [GRASS-user] trouble with v.rast.stats under
WINGRASS
Niels Thevs
nt001582 at uni-greifswald.de
Thu Apr 10 04:48:37 EDT 2008
Now, I installed WINGRASS 63 RC6. The errors regarding v.rast.stats (see
below) do not occur anymore, but the command v.rast.stats did not come
to en end. I tried a very small vector layer wit 5 polygons, but still
v.rast.stats calculated more than an hour without any result.
Unfortunately, under RC6 I was not able to import shape files properly.
The dbf file was not created.
Have many thanks for your kind help and advice
Best regards
Niels
Martin Landa schrieb:
> Hi,
> 2008/4/9, Niels Thevs <nt001582 at uni-greifswald.de>:
>> have many thanks for your reply. Unfortunately, I cannot download the RC6
>>from the download site under grass.itc.it. Where else can I find it ?
> http://grass.osgeo.org/grass63/source/
> Martin
>> Moritz Lennert schrieb:
>>>On 08/04/08 23:03, Moritz Lennert wrote:
>>>>On 08/04/08 18:04, Niels Thevs wrote:
>>>>>Dear GRASS users,
>>>>>I am using WINGRASS 6.3 (RC5) and tried the command v.rast.stats. But
>>I encountered the error messages below, though the vector and raster are in
>>the same mapset.
>>>>>split1 at PERMANENT_3280.0 is not in the current mapset (PERMANENT)
>>>>>An error occurred while converting vector to raster
>>>>>G__open(r): mapset (PERMANENT) doesn't match xmapset
>>(PERMANENT_3280.0)
>>(PERMANENT_3280.0)
>>>>>Does anybody know, how to overcome this problem ?
>>>>This was fixed by Hamish here
>>http://trac.osgeo.org/grass/changeset/30136
>>>>but apparently it did not get backported.
>>>Sorry, I correct myself: it was backported to RC6, so just install that
>>version and you should be fine.
>>>Moritz
>> Dr. Niels Thevs
>> Chair of Geobotany and Landscape Ecology
>> Institute of Botany and Landscape Ecology
>> Greifswald University
>> Grimmer Strasse 88
>> 17487 Greifswald
>> Germany
>> Tel.: +49-3834-86-4137
>> Fax: +49-3834-86-4114
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
