[GRASS-user] Orthorectification of Historic Aerial Photographs
Shaun & Melissa Busler
buslers at gmail.com
Thu Apr 10 11:29:29 EDT 2008
Thank you so much for your response! The resources you linked to were very
useful. The Erdas paper is especially good. I never heard of MapAnalyst.
I will have to give it a try.
Unfortunately, the focal length of the camera is not on the photo border.
The photo must be too old. Do you have any recommendations on what focal
length I should try? It was taken in 1939 for the USDA Agricultural
Adjustment Administration. If it would help, I could send the image file.
It is about 7 mb in size.
I was using photo2.image as part of the i.ortho.photo UI when I was having
the problems. It may be because I am using GIS-Knoppix. If I use GIMP to
measure the fiducial mark coordinates, do I still need to use photo2.image
or do I just use photo.camera?
Thanks!
Shaun
On Sun, Apr 6, 2008 at 6:18 AM, Maciej Sieczka <tutey at o2.pl> wrote:
> Shaun & Melissa Busler pisze:
> 1) When is i.ortho.photo going to be available for the Windows binaries?
> Dunno. It currently depend on X displays, not easily portable to else than
> Unix.
> 2) The historic aerial photos do not have camera calibration files. I
> > have
> > searched all over and they do not seem to exist anymore. Is there a way
> > to
> > orthorectify the images without the camera calibration files? Can I
> > make
> > some assumptions? If so, what parameters should I enter?
> If the DPI at which photos have been scanned is known to you, you can
> measure the principal point and fiducial marks coordinates in any image
> editing software, like GIMP. Interior orientation results will depend on
> how close is the geometry of the image plane to the geometry of camera's
> optical system, and if/how the photo scan is distorted.
> Idea, not tested: you might try using software like MapAnalyst [1] to
> asses the distortion of the image, which can help you guessing genuine
> fiducial marks coordinates.
> Then you need the focal length. It often is present on the photo border.
> Or guess it :).
> 3) When I tried using photo.2image, I was not prompted with "Look ok?
> > (Y/N)" so I was not able to mark the fiducials.
> photo.2image is not supposed to be used standalone. i.ortho.photo is the
> UI for photo.2image & friends.
> There's plenty of info you might find usefull on the net. eg. [2] [3].
> [1]http://mapanalyst.cartography.ch
> [2]http://support.erdas.com/focus3/files/Aerial_photo.pdf
> [3]
> http://www.pcigeomatics.com/services/support_center/faqs/oe_general_v10.html#no_fiducial
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080410/8728b14f/attachment.html
