R: [GRASS-dev] Re: [GRASS-user] trouble with v.rast.stats underWINGRASS
Niels Thevs nt001582 at uni-greifswald.de
Mon Apr 14 03:17:40 EDT 2008
I installed the full version, not only the corrected script.
Niels
Hamish schrieb:
> Niels Thevs wrote:
>>I installed WINGRASS 63 RC6 and tried again v.rast.stats. Before
>>running it I chose a small region (only a bit more than 2 polygons).
>>The following error messages were printed:
>>:/GRASS/scripts/v.rast.stats: v.db.addcol: command not found
>>DBMI-DBF driver error:
>>Column 'qb4_reg1_n' not found
>>Error in db_execute_immediate()
>>Error while executing: 'UPDATE kacheladdstat SET qb4_reg1_n=1020 WHERE
>>cat=24495'
>>Statistics calculated from raster map <qb050615_4 at PERMANENT> and
>>uploaded to attribute table of vector map <kacheladdstat>.
>>Done.
>>The dbf file of the vector has not been altered.
> "v.db.addcol: command not found" is the key, the rest of the problems are
> just due to that failing. Did you install a full version of GRASS
> 6.3.0rc6 or just upgrade the v.rast.stats script from there?
> In 6.3svn I have just modified v.rast.stats (r30976) to better deal with
> v.db.addcol errors. It already had a test to see if v.db.addcol failed
> (exit code 1), but not if it failed because it couldn't run (for me on
> linux: exit code 127). Now it stops for any error.
> Hamish
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Dr. Niels Thevs
Chair of Geobotany and Landscape Ecology
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4137
Fax:  +49-3834-86-4114
