[GRASS-user] is it possible to import map without providing datum &Projection..????(Urgent!!)
M S mseibel at gmail.com
Tue Apr 15 08:23:28 EDT 2008
If you dont want to deal with projections you can create a location that is
x,y based, without a projection.
If you have know what projection the data is in, and you have the
appropriate location setup, then you can use the -o (override) parameter to
import regardless of the imported data's projection file or conflict stated
upon import.
Mark
On Tue, Apr 15, 2008 at 8:09 AM, Kunal Malik <kunal.malik81 at gmail.com>
wrote:
> Please elaborate ..
> On 4/15/08, M S <mseibel at gmail.com> wrote:
> > There is a location setup option for plain old X,Y coordinates, that are
> > an undefined system.
> > Mark
> >  On Tue, Apr 15, 2008 at 7:34 AM, Kunal Malik <kunal.malik81 at gmail.com>
> > wrote:
> > > Hi !!
> > > and does  datum wgs84 and lcc can co-exist at display.
> > > Thanks & Regards
> > > Kunal Malik
> > > 09871147561
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> Thanks & Regards
> Kunal Malik
> 09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080415/d6575d75/attachment.html
