[GRASS-user] LOS, Fresnel Zones,
Multi-Line wave propagtion and GHz communications
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Apr 17 11:12:19 EDT 2008
On Thu, Apr 17, 2008 at 7:58 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Apr 17, 2008 at 12:05 PM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com> wrote:
> > Dear GRASS community,
> > I would like to simulate the strength of a signal emitted from an antenna
> > and received by a receiver.
> > As a first approach r.los gives a good start. Anyway, more accurate results
> > could be obtained by taking obstruction in the first Fresnel Zone into
> > account. Finally, having a way to calculate the impact on indirect
> > paths/reflections, should lead to a reasonably accurate signal strength map.
> > Did anybody work on some of these issues, possibly in combination with
> > GRASS? Is there a good starting point for the calculation of the obstruction
> > within the first Fresnel Zone. And the reflections?
> Hi Peter,
> reading
> http://en.wikipedia.org/wiki/Fresnel_zone
> I remembered
> Mapping Wi-Fi Network Range with GRASS, Kismet, and python
> http://casoilresource.lawr.ucdavis.edu/drupal/node/470
> Could this be helpful?
Maybe only as an idea of how complicated radio propagation can be. The
referenced page on Wifi / GRASS doesn't really do any important math
or modeling-- rather it was more a test case on interpolating signal
strength measurements.
I am sure that Brad Douglas has some good insight into radio wave
propagation modeling.
There is also an open source application called 'splat' :
http://www.qsl.net/kd2bd/splat.html
I do not know if splat can account for near-surface conditions (i.e.
Fresnel Zone) or higher elevation atmospheric parameters (ionosphere).
It would be nice to have a couple of more robust LOS-like modules in
GRASS for this type of work.
Cheers,
Dylan
