[GRASS-user] Command completion in wxpython-GUI: is it possible(?) + an issue with the EPSG file browser.
Hamish hamish_b at yahoo.com
Thu Apr 17 20:05:06 EDT 2008
Marin:
> Originally file dialog pointed to 'root directory', but anyway I
> figured out that loading other files then 'epsg' fails, since slightly
> different file structure. I will try to fix it ASAP.
It could be better to build those lists from $GISBASE/etc/ogr_csv/ files,
as that is what 'g.proj -c' actually uses.
AFAIK the EPSG files in /usr/share/proj/ are just "decoration" as far as
GRASS is concerned, and may lead to false expectations.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
