[GRASS-user] selecting upstream river segments
ivan marchesini marchesini at unipg.it
Mon Apr 21 02:58:31 EDT 2008
Dear Grass users,
I have a vector stream network map of a single basin (so only a stream
"tree")...
each stream segment is correctly oriented downstream (the direction of
each vector is from higher to lower elevation..)
I would like to select a random segment of the "tree" and automatically
obtain only the upstream segments..
i.e. I would like to obtain a new map containing only the upstream
stream segments of the selected one... (that is the same of removing
those downstream)
obviously I must implement this process into a shell script...
Could you suggest a simple way to solve this little problem?
Can I use the direction of the vectors to solve this problem?
Many thanks
Ivan
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73 at jabber.org
