[GRASS-user] wxpython-GUI fails in grass6.3
Agustin Diez Castillo
Agustin.Diez at uv.es
Mon Apr 21 10:29:04 EDT 2008
El Apr 21, 2008, a las 3:56 PM, William Kyngesburye escribió:
> On Apr 21, 2008, at 2:30 AM, Agustin Diez Castillo wrote:
>> I've downloaded William's Leo binary, the readme states "The
>> wxPython GUI makes use of the system MacPython 2.5 and wxPython
>> 2.8.4. There is no need to install these", but my system asked for
>> a higher python version.
> How did it ask for a newer version? Really, you don't need to
> install a newer one.
A warning in the terminal saying me that the machine has wwpython
2.8.0 and should have 2.8.4 (or the like, I don't rememeber the wording)
>> I've updated wtih
>> http://www.python.org/ftp/python/2.5.2/python-2.5.2-macosx.dmg
>> and
>> http://downloads.sourceforge.net/wxpython/wxPython2.8-osx-unicode-2.8.7.1-universal-py2.5.dmg
>> When starting a new grass instance it refuses wxpython w/o any
>> message, so I try
>> g.gui wxpython
>> and get
>> Fatal Python error: Interpreter not initialized (version mismatch?)
> Now you are working with the python.org python. You must install
> and run the Tiger GRASS binary, which is built to use that. Really,
> the bulk of the GUI doesn't care and should run, it's just the
> digitizer that's tied to the exact wxPython build.
Done and working. But I'm on Leopard.
> Looks like it might be a Python bug? Can you run Python by itself?
I can run GRASS.Tiger so I guess I can
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin] You think you have problems? What are you supposed to do
> if you ARE a maniacally depressed robot? No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
