[GRASS-user] missing dbf table for point theme
christian Brandt
chrisbrandt74 at hotmail.com
Thu Apr 24 12:09:56 EDT 2008
Dear Markus,
the following error message occurs:
DBMI-DBF driver error:
Table 'messstationen' doesn't exist
ERROR: Cannot open table
And that's the statement I used:
v.in.ascii -n 'input=/ output= format=point fs=| skip=0 'columns=x double precision, y double precision' x=1 y=2 z=0 cat=1
Did I set the right numbers for the columns?
Regards
Chris
> Date: Thu, 24 Apr 2008 17:14:24 +0200
> From: neteler at osgeo.org
> To: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] missing dbf table for point theme
> On Thu, Apr 24, 2008 at 5:03 PM, christian Brandt
> wrote:
>> Dear list,
>> I imported points from ascii table into GRASS 6.3 ORC5. Now I would like to assign values to these points. So doing the v.db.connect command GRASS tells me that there is no table for this layer.
> Did you use the "column" parameter?
> What does
> v.info -c yourmap
> say?
> Markus
>> Besides, using the v.db.addtable command to add an attribute table to the layer the message appears that there is already a table linked to the layer.
>> What to do now?
>> Regards
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
