[GRASS-user] execute commands automatically after start of grass
Rainer M Krug
r.m.krug at gmail.com
Fri Aug 1 05:23:10 EDT 2008
On Fri, Aug 1, 2008 at 11:16 AM, Jachym Cepicky
<jachym.cepicky at gmail.com> wrote:
> hi,
> you can adjust anything in .grass.bashrc file
> e.g.
> #!/bin/sh
> export GRASS_ADDON_PATH=$HOME/usr/grass/
> export GRASS_PAGER=/bin/more
Thanks - that looks exactly what I am looking for.
But is there a way of specifying a certain .grass.bashrc which should be used?
The reasoning is that for certain projects I need R and emacs and
would like to start them automatically, for others not. Obviously, I
could use a startup script which renames the apropriate file to
.grass.bashrc, but it would be cleaner to be able to specify it when
starting grass.
> jachym
> [1] http://grass.osgeo.org/grass64/manuals/html64_user/variables.html
> 2008/8/1 Rainer M Krug <r.m.krug at gmail.com>:
>> Hi
>> I am using grass in combination with R, wherefore I have to start R
>> (or emacs) after starting grass.
>> Is there any way, to make this automatic, i.e., can I specify a script
>> which is executed inside grass after it is started?
>> In addition, I only would like that to happen when I start grass in a
>> certain mapset and not in other mapsets.
>> Thanks
>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Plant Conservation Unit
>> Department of Botany
>> University of Cape Town
>> Rondebosch 7701
>> South Africa
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
