[GRASS-user] GRASS export GeoTiff adventure :-)
Markus Metz
markus_metz at gmx.de
Sat Aug 2 16:47:23 EDT 2008
I think exporting colour tables is one big problem [also see 3, 4]:
GeoTIFFs exported from GRASS suddenly became readable after deleting the
colour table before exporting (my own fiddling around). IMHO, there
should be an option to export colour tables with default to no. There
should also be a warning if you really want to export a colour table.
For multiband images (exporting a group), exporting colour tables might
need to be disabled completely. This is easy to implement in the current
version of r.out.gdal. In my experience, Tiffs without a colour table
are indeed useful [contrary to 4], because for imagery, most viewers
have their own contrast enhancement and colour table manipulation
methods. For a raster with labelled categories, a separate text
file/table with labels and maybe a suggested colouring scheme needs to
be provided anyway. I haven't found yet a raster format that gdal can
write where gdal can export category labels from GRASS.
Another issue might be handling of nodata, that is at least a starting
point for testing/fixing.
There might be other problems with the readability of the output of
r.out.gdal, but maybe sorting out the two problems listed above helps a lot.
Having said that, r.out.gdal and GDAL Utility Programs as they are now
are probably unmatched in their compatibility and interoperability [5].
Regards,
Markus
Dylan Beaudette wrote:
> I am glad that this topic is getting some traction again. I have
> noticed that r.out.gdal does not always produce images readable in
> ESRI products. Heck, sometime the resulting TIFF would not even be
> readable by QGIS. This was some time ago, and associated with several
> blog postings / trac tickets:
> Posts:
> 1. http://casoilresource.lawr.ucdavis.edu/drupal/node/337
> 2. http://gfoss.blogspot.com/2008/06/gdal-raster-data-tips-and-tricks.html
> Ticket:
> 3. http://trac.osgeo.org/grass/ticket/73
Other posts:
4. http://lists.osgeo.org/pipermail/grass-dev/2008-February/035987.html
5. http://lists.osgeo.org/pipermail/grass-user/2008-July/045860.html
> It would be a good idea to get this fixed in GRASS64 before marching
> into GRASS7 as import/export operations are fundamental to GIS work.
> Cheers,
> Dylan
