[GRASS-user] exporting only a table from a vector
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Sat Aug 2 18:48:13 EDT 2008
Thanks to all your help,
Several of your suggestions solved my problem with this task.
Kind regards,
miltinho astronauta
brazil
2008/8/2, Moritz Lennert <mlennert at club.worldonline.be>:
> On 02/08/08 02:53, Dylan Beaudette wrote:
>> On Friday 01 August 2008, Nikos Alexandris wrote:
>>> On Fri, 2008-08-01 at 16:19 -0300, Milton Cezar Ribeiro wrote:
>>> 2008/8/1, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
>>> Hi Milton.
>>>> If you use sqlite as DBMS you can open your sqlite.db file
>>>> with
>>>> sqlitebrowser and export your table of interest as a .csv
>>>> file. Later
>>>> you can import for example in openoffice for further editing.
>> db.select should do what you want. I use it regularly to make CSV file for
>> export.
> Or (maybe easier): v.db.select.
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080802/1c7e1ca5/attachment.html
