[GRASS-user] starting grass in text mode prints ..."root"
message twice or once.
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Aug 3 08:15:49 EDT 2008
On Sun, 2008-08-03 at 13:41 +0200, Markus Neteler wrote:
> On Sun, Aug 3, 2008 at 1:30 PM, Nikos Alexandris
> <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > Some time ago launching GRASS 6.3.0RC4 under Ubuntu in text mode [1]
> > gave twice a print-out of:
> > To run a command as administrator (user "root"), use "sudo <command>".
> > See "man sudo_root" for details.
> > Now GRASS 6.3.1svn gives the same double print-out while GRASS 6.4.svn
> > print's out only once!
> > Is it still an Ubuntu-issue?
> > [1] http://www.nabble.com/When-starting-grass-in-text-mode%2C-why...---(Question-of-minor-importance)-td14895992.html
> Did you verify this?
> http://www.nabble.com/Re%3A--GRASS-user--Ubuntu-6.06-Dapper%3A-strange-sudo-hints-printed-a-tstartup-p5691527.html
> Markus
Thanks Markus. It works. Note the "typo" in http://www.nabble.com/RE%
3A-strange-sudo-hints-printed-a-tstartup-td5691550.html#a5691527: It is
"successful" otherwise it wont work.
Schoene Gruesse, Nikos
