[GRASS-user] Cross-validation output
Casagrande Luca thedoktor78 at gmail.com
Mon Aug 4 06:34:40 EDT 2008
Hello everybody,
I am using v.surf.rst to interpolate a bathymetry survey. Following the
examples on the 3rd Grass Book, I have
interpolated the results from the cross-validation procedure to check if
there are areas that need a more accurate sampling.
Most of the surface is ok, but there is a small area where the difference is
very high; you can check it out from this picture:
http://www.thebighouse.biz/data_cv.png
The issue is that there are bigger zones with no points that show a lower
difference value.
Why this?
Thank you very much for your help.
Luca
View this message in context: http://www.nabble.com/Cross-validation-output-tp18808883p18808883.html
Sent from the Grass - Users mailing list archive at Nabble.com.
