[GRASS-user] segmentation fault with r.in.gdal
Daniel Victoria daniel.victoria at gmail.com
Thu Aug 7 20:27:04 EDT 2008
If it's mainly a build problem, try to use Frank's FWTools. Itś
already pre-build gdal binaries and I've used them before for NetCDF
stuff
http://fwtools.maptools.org/
On Thu, Aug 7, 2008 at 7:51 PM, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> I found this bug report that probably explains it...but not sure what to do
> about it..
> https://bugs.launchpad.net/ubuntu/+source/libgdal-grass/+bug/126916
> -vishal
>I
> On Thu, Aug 7, 2008 at 3:16 PM, Vishal Mehta <vishalm1975 at gmail.com> wrote:
>> Yes Daniel,
>> I tried gdal_translate and gdalinfo and both gave me the same result -
>> 'segmentation fault'.
>> -Vishal
>> On Thu, Aug 7, 2008 at 3:05 PM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>>> Hi,
>>> Did you try to import outside of Grass, using gdal_translate instead
>>> of r.in.gdal
>>> Daniel
>>> On Thu, Aug 7, 2008 at 6:16 PM, Vishal Mehta <vishalm1975 at gmail.com>
>>> wrote:
>>> > Hi all,
>>> > I am attempting to import netcdf files into GRASS. I'm using GRASS
>>> > 6.2.2 on
>>> > Ubuntu 8.04LTS.
>>> > I get a 'Segmentation fault' error.
>>> > gdalinfo --formats includes netcdf support; however running
>>> > gdal_translate
>>> > or gdalinfo on the netcdf file returns the same error.
>>> > Help?
>>> > Thanks,
>>> > vishal
>>> > _______________________________________________
>>> > grass-user mailing list
>>> > grass-user at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
