[GRASS-user] vector layer labelling doesn't work....
Moritz Lennert mlennert at club.worldonline.be
Fri Aug 8 11:46:04 EDT 2008
On 08/08/08 17:34, G. Allegri wrote:
>> If I'm not wrong centroids were set on by default. I didn't make this
>> "mistake" before, but I've used labeling lot of times.
> I mean, in some previous versions...
see http://lists.osgeo.org/pipermail/grass-dev/2007-February/028873.html
and following, notably
http://lists.osgeo.org/pipermail/grass-dev/2007-February/028908.html
So, it's been off since 1 1/2 year, at least in trunk...
But, to come back to the labelling issues, AFAICT, all it would take is
this:
Index: display/d.vect/main.c
--- display/d.vect/main.c       (révision 32646)
+++ display/d.vect/main.c       (copie de travail)
@@ -565,6 +565,7 @@
             break;
         case 'a':
             display |= DISP_ATTR;
+           type |= GV_CENTROID;
             break;
         case 'z':
             display |= DISP_ZCOOR;
Martin, are you really against this ? Anyone else ? Otherwise, I would
commit.
Moritz
