[GRASS-user] Concave hull of a set of points (alphashapes)
Moritz Lennert mlennert at club.worldonline.be
Sun Aug 10 09:47:13 EDT 2008
On 10/08/08 09:21, Maciej Sieczka wrote:
> Andruit at gmx.de pisze:
>> Hello,
>> I have a set of points and would like to compute the concave hull of it.
>> Is it possible within grass and has anybody done it before.
AFAIK, the problem with concave hull is that there is not one definitive
answer, as you there are different ways of drawing the concave hull...
> (Not tested idea:)
> Connect all points with v.distance. Get rid of doubled lines with
> v.clean tool=rmdupl. Turn lines into boundaries with v.type - this
> creates areas without centroids. Add a centroid to each area. Make sure
> each centroid has the same category (use v.category if needed). Dissolve
> areas (v.dissolve) - you should get a single area with nodes only at the
> most outer points you had in your input dataset.
Which IIUC is the convex hull, i.e. the same result as v.hull. But you
can reach something like a concave hull through the following steps
(building on Maciej's suggestion):
- create map of lines connecting all points (I find it easier to do this
with v.net.visibility, but v.distance works also)
- add a table with a column 'cat' and a column 'length double precision'
and categories to these lines (v.db.addtable, v.category)
- upload the length of each line to the table (v.to.db)
- visually identify a length threshold above which the lines should not
be used
- extract only those lines below that threshold (v.extract
where="length<MAXLENGTH)
- convert the lines to boundaries (v.type)
- break overlapping lines (v.clean tool=break, there shouldn't be any
duplicate lines, but just in case you can also use rmdupl)
- add centroids with the same category value to the boundaries
(v.centroids step=0)
- dissolve the areas into one (v.dissolve)
I've attached an image to show the results:
green points: original points
blue line: result of v.hull
red line: result of above algorithm
Moritz
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080810/94ed21ae/concave_hull-0001.jpg
