[GRASS-user] grass 6.3.0 solaris 10 install errors
Glynn Clements
glynn at gclements.plus.com
Tue Aug 12 03:48:16 EDT 2008
Hamish wrote:
> > The files are deleted during make, but I'm not sure exactly when
> > it happens..
> while make runs, can you monitor the directory structure in another
> terminal window and track down when it happens that way?
> perhaps:
> watch ls -l include/Make/
> then quickly ^C make, back up a little, and see where in the build it
> got up to? timing may have to be fast....
> or chmod one of the vanishing files to be read-only then see if `make`
> stops with an error at some point when it can't remove it?
To delete a file, you need write permission on the directory. You
don't need any permissions on the file itself.
But running "chmod a-w include/Make" after "configure" but before
"make" may well provide useful information.
