[GRASS-user] GEM and Add-ons
Raphael Saldanha saldanha.plangeo at gmail.com
Tue Aug 12 11:26:37 EDT 2008
Ok, I put the file (r.colors.sttdev) on C:\GRASS\scripts.
On the output windowm, if I enter with r.colors.sttdev and Run, seems GRASS
recognize the command. But how in the syntax to inform the input and other
parametres?
Can I found this in the code?
1     #!/bin/sh
2
3     #
4     # MODULE:       r.colors.stddev
5     # AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago
Univeristy,
6     #                 New Zealand
7     # PURPOSE:
8     #
9     # COPYRIGHT:    (c) 2007 Hamish Bowman, and the GRASS Development Team
10     #               This program is free software under the GNU General
Public
11     #               License (>=v2). Read the file COPYING that comes with
12     #               for details.
13     #
14
15
16     #%Module
17     #% description: Set color rules based on stddev from a map's mean
value.
18     #% keywords: raster
19     #%End
20     #% option
21     #% key: input
22     #% type: string
23     #% gisprompt: old,cell,raster
24     #% key_desc: name
25     #% description: Name of input raster map
26     #% required: yes
27     #%end
28     #%flag
29     #% key: b
30     #% description: Color using standard deviation bands
31     #%end
32     #%flag
33     #% key: z
34     #% description: Force center at zero
35     #%end
36
37
38     if  [ -z "$GISBASE" ] ; then
39         echo "You must be in GRASS GIS to run this program." 1>&2
40         exit 1
41     fi
42
43     if [ "$1" != "@ARGS_PARSED@" ] ; then
44         exec g.parser "$0" "$@"
45     fi
46
47
48     eval `r.univar -g "$GIS_OPT_INPUT"`
49     # $? is result of the eval not r.univar (???)
50     #if [ $? -ne 0 ] ; then
51     #   echo "ERROR: Problem running r.univar" 1>&2
52     #   exit 1
53     #fi
54
55
56     if [ $GIS_FLAG_Z -eq 0 ] ; then
57
58        MEAN_MINUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 - 2*$2}'`
59        MEAN_PLUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 + 2*$2}'`
60
61        if [ $GIS_FLAG_B -eq 0 ] ; then
62          # smooth free floating blue/white/red
63          r.colors "$GIS_OPT_INPUT" color=rules << EOF
64            0% blue
65            $MEAN_MINUS_2STDEV blue
66            $mean white
67            $MEAN_PLUS_2STDEV red
68            100% red
69     EOF
70        else
71          # banded free floating  black/red/yellow/green/yellow/red/black
72          MEAN_MINUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 - $2}'`
73          MEAN_MINUS_3STDEV=`echo "$mean $stddev" | awk '{print $1 -
3*$2}'`
74          MEAN_PLUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 + $2}'`
75          MEAN_PLUS_3STDEV=`echo "$mean $stddev" | awk '{print $1 +
3*$2}'`
76
77          # reclass with labels only works for category (integer) based
maps
78          #r.reclass input="$GIS_OPT_INPUT"
output="${GIS_OPT_INPUT}.stdevs" << EOF
79
80          # >3 S.D. outliers colored black so they show up in d.histogram
w/ white background
81          r.colors "$GIS_OPT_INPUT" color=rules << EOF
82            0% black
83            $MEAN_MINUS_3STDEV black
84            $MEAN_MINUS_3STDEV red
85            $MEAN_MINUS_2STDEV red
86            $MEAN_MINUS_2STDEV yellow
87            $MEAN_MINUS_1STDEV yellow
88            $MEAN_MINUS_1STDEV green
89            $MEAN_PLUS_1STDEV green
90            $MEAN_PLUS_1STDEV yellow
91            $MEAN_PLUS_2STDEV yellow
92            $MEAN_PLUS_2STDEV red
93            $MEAN_PLUS_3STDEV red
94            $MEAN_PLUS_3STDEV black
95            100% black
96     EOF
97        fi
98
99
100     else
101        # data centered on 0  (e.g. map of deviations)
102        r.mapcalc "r_col_stdev_abs_$$ = abs($GIS_OPT_INPUT)"
103        eval `r.info -r "r_col_stdev_abs_$$"`
104
105        # current r.univar truncates percentage to the base integer
106        STDDEV2=`r.univar -eg "r_col_stdev_abs_$$" perc=95.4500 | grep
^percentile | cut -f2 -d=`
107
108        if [ $GIS_FLAG_B -eq 0 ] ; then
109          # zero centered smooth blue/white/red
110          r.colors "$GIS_OPT_INPUT" color=rules << EOF
111            -$max blue
112            -$STDDEV2 blue
113            0 white
114            $STDDEV2 red
115            $max red
116     EOF
117        else
118          # zero centered banded  black/red/yellow/green/yellow/red/black
119
120          # current r.univar truncates percentage to the base integer
121          STDDEV1=`r.univar -eg "r_col_stdev_abs_$$" perc=68.2689 | grep
122          STDDEV3=`r.univar -eg "r_col_stdev_abs_$$" perc=99.7300 | grep
123
124          # >3 S.D. outliers colored black so they show up in d.histogram
w/ white background
125          r.colors "$GIS_OPT_INPUT" color=rules << EOF
126            -$max black
127            -$STDDEV3 black
128            -$STDDEV3 red
129            -$STDDEV2 red
130            -$STDDEV2 yellow
131            -$STDDEV1 yellow
132            -$STDDEV1 green
133            $STDDEV1 green
134            $STDDEV1 yellow
135            $STDDEV2 yellow
136            $STDDEV2 red
137            $STDDEV3 red
138            $STDDEV3 black
139            $max black
140     EOF
141        fi
142
143        g.remove rast="r_col_stdev_abs_$$" --quiet
144     fi
On Tue, Aug 12, 2008 at 11:50 AM, Martin Wegmann <
wegmann at biozentrum.uni-wuerzburg.de> wrote:
> Hello Raphael,
> just download it and call the script within the GRASS shell
> sh r.colors.stddev
> you have to define the input on the command line. The GUI won't work with
> this
> method.
> regards, Martin
> On Dienstag, 12. August 2008 16:03:16 Raphael Saldanha wrote:
> > Hi!
> > Where can I download GEM?  I'm a newbie and need to use an add-onn
> > (r.colors.stddev), can someone give some instructions?
> > GRASS 6.3.0 running on Windows :-(
> > Regards,
> > Raphael Saldanha
> > BRAZIL
Atenciosamente,
Raphael Saldanha
Lucille Ball  - "The secret of staying young is to live honestly, eat
slowly, and lie about your age."
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080812/930345de/attachment-0001.html
