[GRASS-user] GEM and Add-ons
Martin Wegmann
martin.wegmann at uni-wuerzburg.de
Tue Aug 12 11:45:37 EDT 2008
On Dienstag, 12. August 2008 17:26:37 you wrote:
> Ok, I put the file (r.colors.sttdev) on C:\GRASS\scripts.
> On the output windowm, if I enter with r.colors.sttdev and Run, seems GRASS
> recognize the command. But how in the syntax to inform the input and other
> parametres?
> Can I found this in the code?
yes, but easier just do:
sh r.colors.stddev --help
or look at line 16-35 there you finde 'input', 'key: b' and 'key:z' and the
corresponding description below it. But just the input is required hence
sh r.colors.stddev input=YOUR_RASTER
should work.
Martin
> 1 #!/bin/sh
> 2
># 3 #
> 4 # MODULE: r.colors.stddev
> 5 # AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago
> Univeristy,
> 6 # New Zealand
> 7 # PURPOSE:
> 8 #
> 9 # COPYRIGHT: (c) 2007 Hamish Bowman, and the GRASS Development
> Team 10 # This program is free software under the GNU
> General Public
> 11 # License (>=v2). Read the file COPYING that comes
> with GRASS
> 12 # for details.
> 13 #
> 14
>## 15
> 16 #%Module
> 17 #% description: Set color rules based on stddev from a map's mean
> value.
> 18 #% keywords: raster
> 19 #%End
> 20 #% option
> 21 #% key: input
> 22 #% type: string
> 23 #% gisprompt: old,cell,raster
> 24 #% key_desc: name
> 25 #% description: Name of input raster map
> 26 #% required: yes
> 27 #%end
> 28 #%flag
> 29 #% key: b
> 30 #% description: Color using standard deviation bands
> 31 #%end
> 32 #%flag
> 33 #% key: z
> 34 #% description: Force center at zero
> 35 #%end
> 36
> 37
> 38 if [ -z "$GISBASE" ] ; then
> 39 echo "You must be in GRASS GIS to run this program." 1>&2
> 40 exit 1
> 41 fi
> 42
> 43 if [ "$1" != "@ARGS_PARSED@" ] ; then
> 44 exec g.parser "$0" "$@"
> 45 fi
> 46
> 47
> 48 eval `r.univar -g "$GIS_OPT_INPUT"`
> 49 # $? is result of the eval not r.univar (???)
> 50 #if [ $? -ne 0 ] ; then
> 51 # echo "ERROR: Problem running r.univar" 1>&2
> 52 # exit 1
> 53 #fi
> 54
> 55
> 56 if [ $GIS_FLAG_Z -eq 0 ] ; then
> 57
> 58 MEAN_MINUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 -
> 2*$2}'` 59 MEAN_PLUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 +
> 2*$2}'` 60
> 61 if [ $GIS_FLAG_B -eq 0 ] ; then
> 62 # smooth free floating blue/white/red
> 63 r.colors "$GIS_OPT_INPUT" color=rules << EOF
> 64 0% blue
> 65 $MEAN_MINUS_2STDEV blue
> 66 $mean white
> 67 $MEAN_PLUS_2STDEV red
> 68 100% red
> 69 EOF
> 70 else
> 71 # banded free floating black/red/yellow/green/yellow/red/black
> 72 MEAN_MINUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 -
> $2}'` 73 MEAN_MINUS_3STDEV=`echo "$mean $stddev" | awk '{print $1
> - 3*$2}'`
> 74 MEAN_PLUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 + $2}'`
> 75 MEAN_PLUS_3STDEV=`echo "$mean $stddev" | awk '{print $1 +
> 3*$2}'`
> 76
> 77 # reclass with labels only works for category (integer) based
> maps
> 78 #r.reclass input="$GIS_OPT_INPUT"
> output="${GIS_OPT_INPUT}.stdevs" << EOF
> 79
> 80 # >3 S.D. outliers colored black so they show up in d.histogram
> w/ white background
> 81 r.colors "$GIS_OPT_INPUT" color=rules << EOF
> 82 0% black
> 83 $MEAN_MINUS_3STDEV black
> 84 $MEAN_MINUS_3STDEV red
> 85 $MEAN_MINUS_2STDEV red
> 86 $MEAN_MINUS_2STDEV yellow
> 87 $MEAN_MINUS_1STDEV yellow
> 88 $MEAN_MINUS_1STDEV green
> 89 $MEAN_PLUS_1STDEV green
> 90 $MEAN_PLUS_1STDEV yellow
> 91 $MEAN_PLUS_2STDEV yellow
> 92 $MEAN_PLUS_2STDEV red
> 93 $MEAN_PLUS_3STDEV red
> 94 $MEAN_PLUS_3STDEV black
> 95 100% black
> 96 EOF
> 97 fi
> 98
> 99
> 100 else
> 101 # data centered on 0 (e.g. map of deviations)
> 102 r.mapcalc "r_col_stdev_abs_$$ = abs($GIS_OPT_INPUT)"
> 103 eval `r.info -r "r_col_stdev_abs_$$"`
> 104
> 105 # current r.univar truncates percentage to the base integer
> 106 STDDEV2=`r.univar -eg "r_col_stdev_abs_$$" perc=95.4500 | grep
> ^percentile | cut -f2 -d=`
> 107
> 108 if [ $GIS_FLAG_B -eq 0 ] ; then
> 109 # zero centered smooth blue/white/red
> 110 r.colors "$GIS_OPT_INPUT" color=rules << EOF
> 111 -$max blue
> 112 -$STDDEV2 blue
> 113 0 white
> 114 $STDDEV2 red
> 115 $max red
> 116 EOF
> 117 else
> 118 # zero centered banded
> black/red/yellow/green/yellow/red/black 119
> 120 # current r.univar truncates percentage to the base integer
> 121 STDDEV1=`r.univar -eg "r_col_stdev_abs_$$" perc=68.2689 | grep
> 122 STDDEV3=`r.univar -eg "r_col_stdev_abs_$$" perc=99.7300 | grep
> 123
> 124 # >3 S.D. outliers colored black so they show up in
> d.histogram w/ white background
> 125 r.colors "$GIS_OPT_INPUT" color=rules << EOF
> 126 -$max black
> 127 -$STDDEV3 black
> 128 -$STDDEV3 red
> 129 -$STDDEV2 red
> 130 -$STDDEV2 yellow
> 131 -$STDDEV1 yellow
> 132 -$STDDEV1 green
> 133 $STDDEV1 green
> 134 $STDDEV1 yellow
> 135 $STDDEV2 yellow
> 136 $STDDEV2 red
> 137 $STDDEV3 red
> 138 $STDDEV3 black
> 139 $max black
> 140 EOF
> 141 fi
> 142
> 143 g.remove rast="r_col_stdev_abs_$$" --quiet
> 144 fi
> On Tue, Aug 12, 2008 at 11:50 AM, Martin Wegmann <
> wegmann at biozentrum.uni-wuerzburg.de> wrote:
> > Hello Raphael,
> > just download it and call the script within the GRASS shell
> > sh r.colors.stddev
> > you have to define the input on the command line. The GUI won't work with
> > this
> > method.
> > regards, Martin
> > On Dienstag, 12. August 2008 16:03:16 Raphael Saldanha wrote:
> > > Hi!
> > > Where can I download GEM? I'm a newbie and need to use an add-onn
> > > (r.colors.stddev), can someone give some instructions?
> > > GRASS 6.3.0 running on Windows :-(
> > > Regards,
> > > Raphael Saldanha
> > > saldanha.plangeo at gmail.com
> > > BRAZIL
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Remote Sensing and Biodiversity Unit
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Phone: +49-(0)931-888-4797
Fax: +49-(0)931-888-4961
Email: martin.wegmann at uni-wuerzburg.de
