[GRASS-user] grass6.4 develbrunch revision 32726: undefined
reference to `G_no_gisinit'
Michael Barton
michael.barton at asu.edu
Tue Aug 12 12:47:34 EDT 2008
It looks from this snippit that there is some kind of problem with
your gdal installation. Did you do a clean checkout from the svn of
develbranch_6?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Aug 12, 2008, at 9:30 AM, G. Allegri wrote:
> Noway.
> Even switching to develbrunch I receive the same error:
> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
> It appears for many binaries (various vector, raster and others
> commands).
> I also receive tens of warnings, but it's secondary...
> 2008/8/12 Michael Barton <michael.barton at asu.edu>:
>> Let me know if this solves the issue.
>> Michael
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Aug 12, 2008, at 9:14 AM, G. Allegri wrote:
>>> Anyway, as Michel has noted from my #254 ticket, I hadn't switch to
>>> develbranch_6 yet, so I was trying to compile grass 7 (in trunk). In
>>> fact I was receiving tons of errors... :-)
>>> I'm doing a brand new checkout from develbranch_6 right now.
>>>> My understanding is that if you do a make distclean, you do not
>>>> need to
>>>> do a
>>>> make clean too.
>>>> Michael
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>> On Aug 12, 2008, at 9:02 AM, Nikos Alexandris wrote:
>>>>> On Tue, 2008-08-12 at 08:45 -0700, Michael Barton wrote:
>>>>>> On Aug 12, 2008, at 2:23 AM, <grass-user-request at lists.osgeo.org>
>>>>>> wrote:
>>>>>>> Date: Tue, 12 Aug 2008 11:21:19 +0200
>>>>>>> From: "Martin Landa" <landa.martin at gmail.com>
>>>>>>> Subject: Re: [GRASS-user] grass6.4.svn revision32686: failed to
>>>>>>> compile r.terraflow and nviz2
>>>>>>> To: "G. Allegri" <giohappy at gmail.com>
>>>>>>> Cc: grassuser <grass-user at lists.osgeo.org>
>>>>>>> Message-ID:
>>>>>>> <f8fe65c40808120221o21b8ce0ax5d816981a5a358c3 at mail.gmail.com>
>>>>>>> Content-Type: text/plain; charset=ISO-8859-1
>>>>>>> Hi,
>>>>>>> 2008/8/12 G. Allegri <giohappy at gmail.com>:
>>>>>>>> neither r.terraflow nor nviz2.
>>>>>>>> From the error log, it seems to me that nviz library name is
>>>>>>>> missing,
>>>>>>> re-run configure script to fix it.
>>>>>>> Martin
>>>>>> Maybe do a make clean or make distclean before compiling.
>>>>> I always thought both are necessary (?) after a configuration
>>>>> and a
>>>>> "make".
>>>>> make clean --> cleans "make"d files
>>>>> make distclean --> cleans configuration files
>>>>> Is that correct?
>>>>> Nikos
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
