[GRASS-user] grass6.4 develbrunch revision 32726: undefined reference to `G_no_gisinit'
Thu Aug 14 00:37:34 EDT 2008
G. Allegri wrote:
> I understand that everything that needs GRASS has to be recompiled if
> this version changes so much to change its interface (QGis-GRASS
> plugin, GRASS-GDAL plugin, etc.). But I would like to know why the new
> develbrunch_6 revision needs the GDAL itself to be recompiled. I can
> understand it if GRASS would need a newer version of GDAL... is this
> the case?
You only need to re-compile GDAL itself if GDAL was built with GRASS
support (--with-grass).
In your original message, you wrote:
> Even switching to develbrunch I receive the same error:
> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
This indicates that your GDAL library was indeed built --with-grass. I
suggest building it without that option, and using the GDAL-GRASS
plugin instead.
If you build GDAL -with-grass, you will need to re-compile GDAL every
time that GRASS is updated from now on. The problem arises from
r32695, which makes G_gisinit() check that libgis was built with the
same version of gis.h as the caller.
The change adds G_gisinit() and G_no_gisinit() macros:
	#define GIS_H_VERSION "$Revision: 32726 $"
	#define G_gisinit(pgm) G__gisinit(GIS_H_VERSION, (pgm))
	#define G_no_gisinit() G__no_gisinit(GIS_H_VERSION)
The value of GIS_H_VERSION is automatically updated to the SVN
revision whenever gis.h is updated.
The change also renames the functions to G__gisinit() and
G__no_gisinit() (which is why you get the "undefined reference" error
when using an old GDAL with a new libgis), and adds version checks:
	int G__gisinit(const char *version, const char *pgm)
	    if (strcmp(version, GIS_H_VERSION) != 0)
		G_fatal_error(_("Incompatible library version for module"));
Any code which uses G_gisinit() or G_no_gisinit() passes the version
of gis.h with which it was compiled to the library functions, which
check that the same version of gis.h was used to compile the library.
The rationale is to avoid having to track down subtle errors caused by
version incompatibilities between libgis and any code which uses it.
Now, if there is an incompatibility, you get a very unsubtle error
telling you that there's an incompatibility.
