[GRASS-user] configure problem
William L. Baker bakerwl at uwyo.edu
Thu Aug 14 10:13:56 EDT 2008
Yes, Glynn, that was the problem. The 6.3.0 source code is fine, and
./configure works fine now. I must have introduced the CR-LF endings by
downloading and unpacking the tar on Windows and copying the unpacked
directories onto a CD, then moving that to Linux. Dumb. It's been a
while since I worked on Linux/GRASS.
Bill B.
Glynn Clements wrote:
> William L. Baker wrote:
>> This should be easy, but I can't figure it out. On Open SUSE 11.0, which
>> has a bash shell, ./configure works fine with all kinds of packages
>> (e.g., gdal, geos), but in grass 6.3, I just typed ./configure, and
>> here's the error message:
>> ./configure: /bin/sh M: bad interpreter: no such file or directory
> My guess is that the configure script has DOS CR-LF line endings, so
> the shebang line is actually:
> 	#!/bin/sh^M
> where ^M is a CR character, which will be treated as part of the
> interpreter name.
> How did you obtain the source code?
