[GRASS-user] grass6.4 develbrunch revision 32726: undefined
reference to `G_no_gisinit'
G. Allegri
giohappy at gmail.com
Thu Aug 14 13:58:06 EDT 2008
I was just writing again... answering to my (stupid) question by myself.
I was getting lost between GDAL and GRASS! :-)
Thanks anyway.
2008/8/14 Glynn Clements <glynn at gclements.plus.com>
> G. Allegri wrote:
> > perfect. I was used to build grass, then build gdal with grass, and
> > then rebuild grass. This time I'll follow your suggestion:
> > I've just built gdal 1.5.2 (without grass) and grass (--with-gdal) ,
> > and now I will compile gdal-grass plugin 1.4.2.
> > Last question (I'm sorry for my ignorance!): why grass configure asks
> > for --with-gdal? Does this option prepare grass to use the gdal-grass
> > plugin?
> GRASS needs GDAL.
> The --with-gdal switch allows the path to the gdal-config script to be
> passed as an argument, in case it isn't in the path, or in case you
> want to use a version other than the one which comes first in the
> path. You can't use --without-gdal or --with-gdal=no; GDAL is
> non-optional.
> However, GRASS doesn't require that GDAL is built with GRASS support,
> or the GDAL-GRASS plugin.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080814/70ff285f/attachment.html
