[GRASS-user] batch job on multiple locations
José Antonio Ruiz Arias jararias at ujaen.es
Fri Aug 15 05:15:50 EDT 2008
Hi Maning,
have you tried Screen tool? (http://www.linuxjournal.com/article/6340) I
use to launch my GRASS scripts (Bash or Python) within a screen session
an, after desattaching, I can keep on working on the GRASS console,
although this must be done carefully if your script is running on the same
mapset that you are working in the GRASS console. But for different mapset
it should work, at least, I hadn't many problems
Cheers,
Jose
> uick question:
> Can you run another GRASS instance from a different Mapset while
> running a GRASS BATCH JOB?
> cheers,
> maning
> On 8/13/08, maning sambale <emmanuel.sambale at gmail.com> wrote:
>> Thanks Dylan!  Your script might be useful in the succeeding stage of
>> my project.
>>> Not sure if this is what you are asking for, but here is an example of
>>> scripted GRASS usage involving two locations:
>>> http://casoilresource.lawr.ucdavis.edu/drupal/node/613
>>> Cheers,
>>> Dylan
>> | __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
>> | '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
>> | /'.-c |Linux registered user #402901, http://counter.li.org/ |
>> | | /T |http://esambale.wikispaces.com|
>> | _)_/LI
> | _)_/LI
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
José A. Ruiz-Arias
Solar Radiation and Atmosphere Modelling Group
http://www.ujaen.es/investiga/tep220
Physics Department, University of Jaén
Campus Lagunillas, Building A3 066
23071 Jaén Spain
Tlf: +34 953 212 474
Fax: +34 953 212 838
