Hello. I can not use the number pi in r.mapcalc. I tried these ways: r.mapcalc 'prueba = pi()' r.mapcalc 'prueba = pi' r.mapcalc 'prueba = PI()' r.mapcalc 'prueba = PI' With the following results: Syntax error Is this normal? Is IP defined within GRASS / r.mapcalc? Thanks for your help. José María
