[GRASS-user] GRASS 6.3 for Ubuntu 8.10 - Intrepid Ibex
Daniel Victoria
daniel.victoria at gmail.com
Mon Dec 1 06:22:01 EST 2008
I unlinked libgdi.so and instalation worked. But now I'm facing a
segmentation fault problem. So I'm strugling, trying to compile
everything from source but my laptop is very slow (an old Transmeta
Crusoe processor...)
If compilation fails I'll try the packages again run the gdb to look
for what is wrong...
Daniel
On Mon, Dec 1, 2008 at 7:10 AM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> hi,
> some people reported this
> try
> sudo unlink /usr/local/lib/libgdi.so
> and
> apt-get install grass
> j
> 2008/11/29 Daniel Victoria <daniel.victoria at gmail.com>:
>> I'm getting the following error when installing grass from les-ejk
>> repository, using Ubuntu 8.10
>> Setting up grass (6.3.0-lesejk2) ...
>> ln: creating symbolic link `/usr/local/lib/libgdi.so': File exists
>> dpkg: error processing grass (--configure):
>> subprocess post-installation script returned error exit status 1
>> Processing triggers for libc6 ...
>> ldconfig deferred processing now taking place
>> Processing triggers for menu ...
>> Errors were encountered while processing:
>> grass
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> Am I missing some package? Do I have something wrong installed?
>> THanks
>> Daniel
>> On Fri, Oct 31, 2008 at 9:43 AM, Jachym Cepicky
>>> Hi,
>>> first version of the GRASS 6.3.0 package for Ubuntu 8.10 can be
>>> apt-geted from http://les-ejk.cz/ubuntu
>>> There is one problem with new wxPython-based GUI, but overall, the
>>> package seems to be working.
>>> Please, let me know, in case, it does not work for you.
>>> Jachym
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky gmail com
>>> URL: http://les-ejk.cz
>>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Jachym Cepicky
> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
