[GRASS-user] grass topography and postgis
Alex Mandel tech_dev at wildintellect.com
Tue Dec 2 00:42:25 EST 2008
Matt B wrote:
> Hi Group,
> I'd like to set up grass to edit / work with data in a postgis database. So
> far I've figured out (and been informed, thanks Richard) that grass stores
> the topologoly data in it's own database and the external database is just
> used for attributes. Is there a way to have grass store the topology data in
> postgis so I can easily work with the data in different applications?
> Thanks
> Matt
Not that I know of (Not a definitive answer) but maybe you should look
at using QGIS as your front-end to Postgis since this is what it was
designed for originally.
Alex
