Re: [GRASS-user] Elevation profile from intersecting shapefiles
Maris Nartiss
maris.gis at gmail.com
Wed Dec 3 04:40:17 EST 2008
Hello Georg,
first - I suggest You to get a copy of GRASS book. It's really good
reading for beginner.
Second - as I noted, v.profile is a new GRASS Add-on [1]. You can
compile it from source only. It requires GRASS 6.4 or 7 (both
unreleased). v.profile README file contains short note how to install
it.
"segmentation faults" on recent Ubuntu version(s?) is a known issue.
IIRC best solution was recompiling GRASS and GDAL from source... You
can search trac and ML archive to see more.
Maris.
1. http://trac.osgeo.org/grass/browser/grass-addons/vector/v.profile
2008/12/3, georgew <gws293 at hotmail.com>:
> Dylan, using v.surf.rst gives me "Segmentation fault", using:
> v.surf.rst input=kahu_vect at kahu layer=1 zcolumn=ELEVATION
> elev=kahu-surf-rast tension=40. segmax=40 npmin=300 dmin=168.547850
> dmax=842.739250 zmult=1.0 --overwrite
> I am on GRASS 6.3, Ubuntu 8.04, AMD64
> Any suggestions please?
> Maris, I cannot find v.profile on my GRASS6.3!
> Regards
> Dylan Beaudette-2 wrote:
>> Dude- It is saturday night. Your request is for a fairly simple
>> operation, but there are several steps.
>> Some hints:
>> 1. convert your contours into a DEM:
>> v.surf.rst
> http://www.nabble.com/Elevation-profile-from-intersecting-shapefiles%E2%80%8F-tp20744104p20808111.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
