Re: [GRASS-user] Elevation profile from intersecting shapefiles‏
georgew gws293 at hotmail.com
Thu Dec 4 02:58:14 EST 2008
Hamish, please forgive my ignorance but I am not sure what you mean. As far
as I know g.region is the means to change the resolution, whether through
the command line or the GUI. Can you please explain how to access and change
the computational region settings.
hamish_b wrote:
> [please don't post in html, it makes it hard to read]
> georgew wrote:
>> PS I tried to play around with resolution in the Region dialog but the
>> display never changed from the same chunky coloured squares.
> you need to change the computational region, not just the display region
> settings. the computational region is what the processing modules will
> use.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Elevation-profile-from-intersecting-shapefiles%E2%80%8F-tp20744104p20828846.html
Sent from the Grass - Users mailing list archive at Nabble.com.
