[GRASS-user] osm data in grass
Torsten Eckart
torecki at arcor.de
Thu Dec 11 16:18:30 EST 2008
Hallo,
could someone give me a hint how to import osm data in to a grass
location.
The module v.in.osm what I download from
http://kripton.kripserver.net/software/v.in.osm/v.in.osm-2007-07-14-00
gives not a good result:
Reading from file /home/torsten/Arbeit/Gis/Daten/osm/heim.osm, writing
to map heim Reading nodes ... [ OK ] (339 nodes)
Reading segs ... [ OK ] (0 segments)
Importing way 1/77 (ID: 3213956) can't read "segcounter": no such
variable while executing
"puts -nonewline "($segcounter segments) ...""
("while" body line 58)
invoked from within
"while {![eof $fchan]} {
gets $fchan line
if {[string match *<way\ id=* $line]} {
incr waycount
set list [split $line]
foreach elem $li..."
(file "/usr/lib/grass/scripts/v.in.osm" line 185)
Additional I do not understand what properties the target location has
to have. Do's v.in.osm transform the data into the right location e.g.:
projection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5661000
south: 5660000
west: 5411000
east: 5412000
nsres: 1
ewres: 1
rows: 1000
cols: 1000
cells: 1000000
Thanks for Your help.
Torsten
Chatterreichbarkeit:
ecki at jabber.chaotic.de
