[GRASS-user] barin option in r.flow module
    Casagrande Luca
    thedoktor78 at gmail.com
    Mon Dec 15 10:37:33 EST 2008
Casagrande Luca wrote:
> Hello everybody,
> I have got some troubles using r.flow with this option..it stays forever
> at the:
> Reading input files: elevation...
> , barrier
> If I remove the barin option, all is fine.
> I am using the DEM from spearfish with GRASS 6.2.3 and latest 6.4svn.
This is how replicate using Spearfish dataset:
g.region rast=elevation.10m
v.to.rast input=streams at PERMANENT output=streamTest use=val type=line
layer=1 value=1 rows=4096 --overwrite
r.null map=streamsTest null=0
r.report units=me map=streamsTest | grep "no data"
r.flow elevin=elevation.10m barin=streamsTest skip=37 bound=9432
flout=testvector lgout=testraster
Thanks and sorry for double post.
Luca
View this message in context: http://www.nabble.com/barin-option-in-r.flow-module-tp21015531p21016012.html
Sent from the Grass - Users mailing list archive at Nabble.com.
