[GRASS-user] Re: Command to summarize the frequency distribution
	table
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Dec 15 10:41:48 EST 2008
On 09/12/08 15:43, SGW00412 at nifty.com wrote:
> Dear Moritz and all
>> r.stats or r.report
> Thank you for profitable advice.
> When this command was used, the table is output as follows:.
> |         Category Information           |  square  |
> |  #|description                         |kilometers|
> |  1| . . . . . . . . . . . . . . . . . .|     37.30|
> |  2| . . . . . . . . . . . . . . . . . .|      5.89|
> |  3| . . . . . . . . . . . . . . . . . .|      5.89|
> |  4| . . . . . . . . . . . . . . . . . .|      7.85|
This means that your elevation map is already a reclassified map with
elevation classes, but that you did not include the information about
the classes in the reclassed map. I.e., using r.reclass, you can do
something like this:
0 thru 10 = 1
but if you want to keep the information about the class amplitude, then
you have to do this (adding a label to each class):
0 thru 10 = 1 0 - 10m
You can also add labels to the existing classes, using r.category. Just
create a text file:
1: 0 - 10 m
2:11 - 20 m
3:21 - 30 m
and run r.category map=YourMap rules=TextFile.
Then r.report will include these labels.
Moritz
