[GRASS-user] grass 6.3 install problem... can't get past splash
screen on centos
Ken Kwasnicki
ken.kwasnicki at gmail.com
Mon Dec 15 13:58:03 EST 2008
hi all,
i've now had this problem on a couple centos 5.1 installations. i first
build and install from source: fftw, proj4, and gdal, make sure i have
all the tcl/tk devel libraries, then install grass 6.3 from source which
compiles without errors but when i go to run it i can select a location
(spearfish->permanent), then the Output window comes up with the
medieval map splash screen which never goes away and none of the other
windows appear. i have to do a kill -9 on the "wish" process to get
rid of the output window and splash screen.
i've successfully installed grass63 on a couple other systems, one of
which was also centos 5.1, but i don't know what i've done differently
this time. and there are no error messages being displayed.
appreciate any thoughts on why this is happening?
thanks,
ken
[apologies if this message appears twice, my first send was from the
wrong address.]
