[GRASS-user] Re: visualising high latitude regions
Brent Wood
b.wood at niwa.co.nz
Tue Dec 16 18:59:20 EST 2008
Yep, GRASS can do it that way, I suggest you look at GMT (http://gmt.soest.hawaii.edu) for quality map production & cartography...
OGR now supports GMT vector (multiline) output, so it is easy to convert data to GMT format for plotting.
Cheers
Brent Wood
Brent Wood
DBA/GIS consultant
NIWA, Wellington
New Zealand
>>> Wouter <wouter.buytaert at scarlet.be> 12/17/08 7:23 AM >>>
Answer to my own question:
- have your data in UTM
- make a grid in a latlong location with v.mkgrid
- reproject the grid to your UTM location with v.proj
- visualise the grid over your data of interest
- add labels with the latlong coordinates
cheers
wouter
On Tue, 16 Dec 2008, Wouter wrote:
> Date: Tue, 16 Dec 2008 14:46:47 -0300 (CLST)
> From: Wouter <wouter.buytaert at scarlet.be>
> To: grass-user at lists.osgeo.org
> Subject: visualising high latitude regions
> Hi all,
> is there a way in GRASS to draw latlong projection data with a non-straight
> coordinate grid? Something like this:
> <http://www.lib.utexas.edu/maps/americas/chile.gif>
> Particularly for high latitudes such as Patagonia, a straight grid gives a
> lot of distortion.
> Any suggestions to do this in other software are welcome. I even don't know
> if ArcGIS does this.
> thanks
> wouter
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
